Joined: 12 Oct 2006 AIDS: 2707 AIDS Rank: UltraNigger Pools: 159 Location: On the dance floor, chargin mah lazer
It may be the HTML the bbcode generates. The twinkie house thing is a custom word censor function I added that only works on posts. It got rather messy doing it the normal way (the flash got embedded in the thread titles). It inserts the actual HTML directly instead of the [flash] bbcode.
I've changed what may be the problem (excess code in the template,I'm not sure what the point of it was). Check if it's working now. _________________ Nigrapedia
EvryoneHasAIDS wrote:
I can't see the flash either, but yesterday I was able to. Now I can't again.
Ok, that actually helps a lot I think. I've returned it to the edit I tried yesterday. See if it's wurkin now. _________________ Nigrapedia
Ok, I think I actually see the problem now. It's something to do with the permissions/user level where the BBCode is related. I'll see if I can fix it.
EDIT: Alright, I think I got it this time. Let me know if you can/can't see the flash now. _________________ Nigrapedia
Joined: 09 Dec 2006 AIDS: 688 AIDS Rank: R. Kelly Pools: 36
Thank you, it works. _________________
I GO TO AMERICA!
You cannot make new pools in this forum You cannot reply to pools in this forum You cannot edit your AIDS in this forum You cannot delete your AIDS in this forum You cannot vote in polls in this forum
