Captain Planet Test Session
This forum is locked: you cannot make, reply to, or edit pools.   This pool is closed: you cannot edit AIDS or make replies.    Pool's Closed Forum Index -> Nigra Radio
AIDS: 4453
PostPosted: Wed Nov 28, 2007 1:52 am    AIDS subject: Reply with quote
If anyone is online right now, tune into the radio and let me know how it sounds.
Sodaz
F-O-E
AIDS: 2110
Pools: 163
PostPosted: Wed Nov 28, 2007 1:58 am    AIDS subject: Reply with quote
I keep hearing random beeps.
http://pools.myminicity.com/
Go there and help the glorious republic of pools closed grow.
Current Population-50
Current monies-7500
We have a small community in the center and some farms. Also we're doing better then pen0sland.
AIDS: 4453
PostPosted: Wed Nov 28, 2007 2:00 am    AIDS subject: Reply with quote
I have never heard a beep before, I have no idea what it is.
Sodaz
F-O-E
AIDS: 2110
Pools: 163
PostPosted: Wed Nov 28, 2007 2:04 am    AIDS subject: Reply with quote
Also now it's skipping a bunch for some reason. :V
Current monies-7500
PostPosted: Wed Nov 28, 2007 2:11 am    AIDS subject: Reply with quote
Hmm, the quality isn't too great only around 80 kbps. It's also skipping around a LOT for some reason....
PostPosted: Wed Nov 28, 2007 2:15 am    AIDS subject: Reply with quote
Stream is downloading pretty steadily. Check CPU usage, etc., if the encoding is falling behind it can cause this sort of skipping. That might explain the little noises too.
AIDS: 4453
PostPosted: Wed Nov 28, 2007 2:22 am    AIDS subject: Reply with quote
Alright, I think it might be my connection for right now. For some reason its been slow the past couple days for almost no reason at all.
I'll make a few more adjustment and play a couple more songs to see if I can get it to working right.
I also split the topics as to not spam Nothing's thread
EDIT: Alright, My connection seems to be going slower than usual. I'll see what I can figure out and try it one more time tomorrow night just to see if I can get things working right or not.
AIDS: 4453
PostPosted: Thu Nov 29, 2007 11:32 pm    AIDS subject: Reply with quote
Alright, Im trying this again and hopefully I got that skipping and what not gone now, or work it out real fast.
Hit me up through a PM or on AIM and let me know how it sounds and if its skipping and how the quality sounds to you.
Its not much of a playlist right now, its just a few songs I threw in real fast just to test this out. If I can get it to working right, I'll dj on the 1st with an epic playlist
EDIT: I got a steady 3 listeners for about half an hour and no one's said a thing.  I guess I finally got it right then
PostPosted: Fri Nov 30, 2007 12:15 am    AIDS subject: Reply with quote
It sounds fine so far.
AIDS: 4453
PostPosted: Fri Nov 30, 2007 12:34 am    AIDS subject: Reply with quote
Alright, The only cut out I had in the entire broadcast was from when I changed the show title to include "LET ME KNOW HOW IT SOUNDS", it had to reconnect to put it up.
So Im up for Djing on the raid, just let me know what time and I'll rock out with my cock out. meatspin
PostPosted: Fri Nov 30, 2007 12:59 am    AIDS subject: Reply with quote
Take what was supposed to be mustardblack's timeslot, if I recall correctly it's on the Google Calender.
This forum is locked: you cannot make, reply to, or edit pools.   This pool is closed: you cannot edit AIDS or make replies.    Pool's Closed Forum Index -> Nigra Radio All times are GMT
