Joined: 12 Jun 2007 AIDS: 1060 AIDS Rank: W.T. Snacks Pools: 42 Location: Bangkok, Thailand
So, after CP's test session, the Nigra radio status window says: "the server on www.smokin-hosting.com takes too long to awnser".
Is this just me? |
barosjn
Joined: 18 Nov 2006 AIDS: 299 AIDS Rank: AIDS Control Team Leader Pools: 9 Location: No idea
Peekachoo wrote: | So, after CP's test session, the Nigra radio status window says: "the server on www.smokin-hosting.com takes too long to awnser".
Is this just me? |
So that could be what's wrong with my broadcasting. _________________ Spam Witch
She shows you a picture of her pet goat. "This is my goat, see?" she says. Dear god, the horror. |
Nope, the status shows perfectly fine here. _________________
What is the direct link, that I can paste into winamp and just directly connect to the stream? |
Joined: 12 Oct 2006 AIDS: 2707 AIDS Rank: UltraNigger Pools: 159 Location: On the dance floor, chargin mah lazer
Is this just me? |
Yes, though not your fault, just happened to pick up server lag. The error showed up in the server logs here but only once, haven't seen any other occurrence today. And that's just the script (which is hosted by the shoutcast provider due to firewall stuff), not the shoutcast server itself.
Peekachoo wrote: | What is the direct link, that I can paste into winamp and just directly connect to the stream? |
radio.poolsclosed.us/listen.pls should do the trick.
barosjn wrote: | So that could be what's wrong with my broadcasting. |
I almost wish it was. Myself and nothing0011 have both tested the server with no lag or skipping problems. On both occasions I know of since the new server that've had problems both mentioned their internets wasn't working right.
We've never been able to figure out the problem when you broadcast. I've had trouble listening since when Sped handled the shoutcast server and I've run out of ideas for exactly why. _________________ Nigrapedia
Rick Santorum wrote: | Nobody hates Rick and gets away with it.
NOBODY. I AM NOT INSECURE. SHUT THE FUCK UP. Â Â Â |
Nyro~n |
MC Scrotal Tuck Warnings : 12 Elite Beat Nigra
Joined: 26 Oct 2006 AIDS: 2298 AIDS Rank: POHST HOAR Pools: 142 Location: The Internet
Nope, working for me right now, it works. _________________
What the fuck is wrong with my internet. I listened to CP's test recording just fine, now I can't connect to nigra radio, and I constantly get the error message in the status window, even after clearing cookies, etc. |
Okay, so I was fucking around with some forum, and Tor was running. I open Poolsclosed, and lo and behold, the status window appears.
I got no idea why it only shows through a proxy, but if I can configure Winamp or iTunes or whatever to run through a fast proxy, I probably got Nigra radio back. |
nothing0011
OSU!
Joined: 31 Oct 2006 AIDS: 846 AIDS Rank: Martin Luther King Jr. Pools: 41
Peekachoo wrote: | Okay, so I was fucking around with some forum, and Tor was running. I open Poolsclosed, and lo and behold, the status window appears.
Your ISP is definitely to blame for this. _________________
nothing0011 wrote: | Peekachoo wrote: | Okay, so I was fucking around with some forum, and Tor was running. I open Poolsclosed, and lo and behold, the status window appears.
Your ISP is definitely to blame for this. |
And blame them I fucking will.
Afroduck, can you post the actual IP adress and port number of the radio again? Just so I actually have some information to give to the ISP customer service girl after I threathen to skin and raep her. |
nothing0011
OSU!
Peekachoo wrote: | nothing0011 wrote: | Peekachoo wrote: | Okay, so I was fucking around with some forum, and Tor was running. I open Poolsclosed, and lo and behold, the status window appears.
69.25.142.48:8042 _________________
nothing0011 wrote: | Peekachoo wrote: | nothing0011 wrote: | Peekachoo wrote: | Okay, so I was fucking around with some forum, and Tor was running. I open Poolsclosed, and lo and behold, the status window appears.
69.25.142.48:8042 |
It's 66.45.227.226:8042 I have no idea where that other IP goes lol.
Also, radio status is here: http://www.smokin-hosting.com/Nigra/radio_status.php in case you need it too. _________________ Nigrapedia
Nyro~n |
nothing0011
OSU!
Afroduck wrote: | nothing0011 wrote: | Peekachoo wrote: | nothing0011 wrote: | Peekachoo wrote: | Okay, so I was fucking around with some forum, and Tor was running. I open Poolsclosed, and lo and behold, the status window appears.
69.25.142.48:8042 |
Also, radio status is here: http://www.smokin-hosting.com/Nigra/radio_status.php in case you need it too. |
I got the other IP by doing an nslookup on radio.poolsclosed.us. _________________
nothing0011 wrote: | Afroduck wrote: | nothing0011 wrote: | Peekachoo wrote: | nothing0011 wrote: | Peekachoo wrote: | Okay, so I was fucking around with some forum, and Tor was running. I open Poolsclosed, and lo and behold, the status window appears.
69.25.142.48:8042 |
I got the other IP by doing an nslookup on radio.poolsclosed.us. |
I get something totally different trying an NSLookup. Neither one is the radio IP or the IP for this server though. radio.poolsclosed.us is a URL redirect for convenience (in case we have to change servers again plus it's easier to remember than IPs). All it does is forward you to the shoutcast server. _________________ Nigrapedia
Nyro~n |
