PeterTheHero
Joined: 10 Jan 2007 AIDS: 37 AIDS Rank: DSFARGEG Pools: 6 Location: Still on Namek
MC Scrotal Tuck Warnings : 12 Elite Beat Nigra
Joined: 26 Oct 2006 AIDS: 2298 AIDS Rank: POHST HOAR Pools: 142 Location: The Internet
Wait, does this mean there's less of a chance we'll be picked up by the filter, or just that we'll be able to see it now?
We should conduct a small experiment... shall we? _________________
PeterTheHero
Testing some copypasta right now. _________________
DREW MOTHA FUCKIN PICKLES! |
Joined: 12 Oct 2006 AIDS: 2707 AIDS Rank: UltraNigger Pools: 159 Location: On the dance floor, chargin mah lazer
The filter system is a server-side thing given they've explained the filter database is purged from time to time or else it overloads the server when it gets too complex.
Most likely all they've done is take the usual stream of conversation data and split it in two. One copy goes through the filter before going out to the flash client, the other bypasses the filter and goes directly to client. You simply get to choose which one is sent to your computer. So Mods and the automated systems would still know the filter was activated even if you don't personally see it any more. _________________ Nigrapedia
Rick Santorum wrote: | Nobody hates Rick and gets away with it.
NOBODY. I AM NOT INSECURE. SHUT THE FUCK UP. Â Â Â |
Nyro~n |
Joined: 12 Jun 2007 AIDS: 1060 AIDS Rank: W.T. Snacks Pools: 42 Location: Bangkok, Thailand
So basically they made it so 13 year olds can cyber better in Habbo? |
Peekachoo wrote: | So basically they made it so 13 year olds can cyber better in Habbo? |
Yep.
And we can raep them better.  _________________ Nigrapedia
Nyro~n |
LANDO Warnings : 3
Joined: 02 Jan 2008 AIDS: 180 AIDS Rank: Pool Raider Pools: 1 Location: CLOUD CITY
I'm tempted to leave it on, more words going through filter makes their servers get raeped harder. _________________ POOL IS CLOSED |
LANDO wrote: | I'm tempted to leave it on, more words going through filter makes their servers get raeped harder. |
Actually, it'll aep them anyway. As long as someone has the filter option on, it has to be processed (and it probably would still do it anyway, even if it didn't get sent out to anyone). _________________ Nigrapedia
Nyro~n |
Reagan
Joined: 24 Jan 2008 AIDS: 116 AIDS Rank: Pool Raider Pools: 12 Location: Ausfag
Afroduck wrote: | LANDO wrote: | I'm tempted to leave it on, more words going through filter makes their servers get raeped harder. |
Actually, it'll aep them anyway. As long as someone has the filter option on, it has to be processed (and it probably would still do it anyway, even if it didn't get sent out to anyone). |
So it still pays to keep it on in the long run amirite? |
White Ranger Warnings : 3 TIGER POWER!
Joined: 11 Jan 2007 AIDS: 1655 AIDS Rank: Samuel L. Jackson Pools: 19
Also tricking innocent habbofags to remove the filter then onto commencing raep. _________________ SIXTY NIGGERS |
Reagan wrote: | Afroduck wrote: | LANDO wrote: | I'm tempted to leave it on, more words going through filter makes their servers get raeped harder. |
It doesn't matter. Wether you have the filter on or off, the chat gets filtered anyways and sent to two different chat channels. One of the channels filters things to 'bobba', the other doesn't. Your filter settings simply decide what chat channel you listen to, so using 'fuck' will lag the servers just like it would before, even if you have your filter off. |
LANDO Warnings : 3
Peekachoo wrote: | Reagan wrote: | Afroduck wrote: | LANDO wrote: | I'm tempted to leave it on, more words going through filter makes their servers get raeped harder. |
It doesn't matter. Wether you have the filter on or off, the chat gets filtered anyways and sent to two different chat channels. One of the channels filters things to 'bobba', the other doesn't. Your filter settings simply decide what chat channel you listen to, so using 'that fucking wordfilter' will lag the servers just like it would before, even if you have your filter off. |
Alright, that makes sense, but still, this is an hueg change. _________________ POOL IS CLOSED |
I'm just going to leave it on to allow me to see what most Habboefags will be seeing. _________________
ReiClone88 wrote: | I'm just going to leave it on to allow me to see what most Habboefags will be seeing. |
Most habbofags will turn it off for hawt pixel cyb0rz.
But you should keep it turned on now that you're a father, you need to be responsible. |
Peekachoo wrote: | ReiClone88 wrote: | I'm just going to leave it on to allow me to see what most Habboefags will be seeing. |
But you should keep it turned on now that your a father, you need to be responsible. | Forgot about the cybering, although I'll leave it on since I tend to target the emotionally weak which will be leaving theirs on. _________________
