This banner was made by redshoepaul.
How to multilog on a dual core system.
iamacup
AIDS: 9
PostPosted: Thu Jan 04, 2007 1:01 am    AIDS subject: How to multilog on a dual core system. Reply with quote
Use Internet Explorer
because FF uses a single process the OS ties it to a single core of the CPU (because windows is crap and ff isnt quite upto speed with dual cores yet - along with everything else)
where as IE uses 1 process per instance (or window) so you can actualy run about twice as many habbo clients without cpu stalling.
just a tip :lol:
antwonee
AIDS: 3
PostPosted: Thu Jan 04, 2007 3:13 am    AIDS subject: Reply with quote
jeez, i bought my core 2 duo setup for the sole purpose of multiloging for raids. thanks for the tip
shortcat500get
AIDS: 546
AIDS Rank: Mudkip Squad
Pools: 17
PostPosted: Thu Jan 04, 2007 4:28 am    AIDS subject: Reply with quote
ha ha!
owned
View nigra's profile Send private message Visit poster's website AIM Address MSN Messenger
iamacup
AIDS: 9
PostPosted: Fri Jan 05, 2007 11:19 am    AIDS subject: Reply with quote
but the benefit is you get loads more :P
i can get about 24 without death and about 30 if i push it :D
