Paintball Guns (also known as "markers) expel paintballs at the opponent in the game, paintball. Paintball markers use carbon dioxide (CO2) and nitrogen (N2) or compressed air to fire the paintball out.
Many markers have large refillable cylinders, or tanks, which can produce more than a hundred shots. Others use powerlets, which can store carbon dioxide and are much smaller and less powerful.
Here is some information about the basic mechanism of a paintball gun...
Of course, there are paintball markers which have a different structure and way of working. But basically paintballs are forced out by a bolt in the main body of the gun. This bolt is moved by a flow of air. There is also a cocking mechanism, which means that the paintball is put in place of the already shot paintball in the firing chamber.
A paintball gun can be re-cocked by either pump or an automatic machine. The place in the gun where the paintball is waiting for the rush of air to throw it out is called a chamber or a breech.
As it was mentioned before, not all markers have the same structure and way of working, and according to their differences, paintball-guns are divided into five main groups:
pumps
semi-automatics
pistols
electronic
and stock Paintball Guns .
Pumps are the cheapest of all markers (it depends on the model, but statistically, they are cheaper than any other Paintball Guns ). And paintball pumps work exactly the same way like pump-action shotguns. Paintball pumps are quite different from semi-automatic paintball markers, because you have to |
Firingmehlazer
Nigra Lazer Squad
Joined: 28 Jan 2007 AIDS: 1230 AIDS Rank: W.T. Snacks Pools: 12 Location: ????
I'ma Charging meh Paintball gun _________________
Inverted Scrotum
Joined: 05 Feb 2007 AIDS: 51 AIDS Rank: FGSFDS Pools: 1
Go spam somone elses forum. |
UFATCOW
Joined: 28 Nov 2006 AIDS: 82 AIDS Rank: Pool Closer Pools: 1
Is that a Bot or an actual idiot? _________________ Bruh |
Dr. Katz
Professional Therapist
Joined: 09 Oct 2006 AIDS: 1281 AIDS Rank: W.T. Snacks Pools: 90 Location: In my office
....................................,.- _________________ Hello I am Dr. Katz.
Inverted Scrotum
UFATCOW wrote: | Is that a Bot or an actual idiot? |
I didn't see the link in his post so i figured he was an retard
But i guess it's a bot
What happened to teh bot collection?
:3 |
Firingmehlazer
Nigra Lazer Squad
Inverted Scrotum wrote: | UFATCOW wrote: | Is that a Bot or an actual idiot? |
:3 | Probably a bot.
HOW DO I SHOT PAINTBALL GUN? _________________
Dr. Katz
lulz gay habbofagz
Joined: 08 Feb 2007 AIDS: 31 AIDS Rank: MOD-Cleo Pools: 1
hyperddude
Joined: 13 Dec 2006 AIDS: 411 AIDS Rank: WRYYYYYYYYYYYYYYYYYYYYYYYYY Pools: 32 Location: Blocking Pool
IMMA CHARGIN' MAH PAINTBALL GUN
