This banner was made by LOLTOAST.
Drawball
N0_Name
AIDS: 1
AIDS Rank: joecoolstar
PostPosted: Sun Aug 05, 2007 4:29 pm    AIDS subject: Drawball Reply with quote
We are going to draw this image at this location.
http://www.drawball.com/4r7orsx
We need 7-10 people helping. EBW has 2-5 people cleaning it every day.No one wirte on the ball untill we save up to 100%ink. EBWF has had this logo up for 3 months. They take this logo srsly. So lets close the pool on them.
Puzzle Answer
Zoom in at 100% and click any place on the ball.
Note: There are a variety of ways to solve the puzzle. If you can't figure it out, use the guide and after a few times it should come natural.
Tips:
Code:
The smaller the dot you use the more ink you save. Dont use the biggest one ever. It is a HUGE waste of ink. It takes longer, but saves a lot more.
Code:
And I am pretty sure your ink grows faster if you have more ink, so you get from 75 to 100 faster then you do from 0 to 25. So never use 100% of your ink. Always leave some 10%-15% left, and your ink will come in quicker. Also, dont actually wait for it to get to 100%. If you come on and its in the 90s, use it. If you wait for it to get to 100, then there will likely be at least a few hours in which it is sitting at 100% not gaining anything. If you always keep it under 100, it will always be gaining ink.
Code:
Don't let your ink go below 40% because once it's there about every 18-24 hours it will gain 40% so you'll be at 80% per day. That's a good spot to get max ink. If you use all your ink at once you will only get like 15% a day so don't go past 40%!
Code:
left click and hold, right click, then left click anywhere you want to draw the line, and it is perfectly straight. Right click and zoom in for more detail.
