This banner was made by LOLTOAST.
Fighting Away From The Legion Guide
This forum is locked: you cannot make, reply to, or edit pools.   This pool is closed: you cannot edit AIDS or make replies.    Pool's Closed Forum Index -> Sherwood Dungeon Archive
PostPosted: Sun Aug 26, 2007 6:39 pm    AIDS subject: Fighting Away From The Legion Guide Reply with quote
Through tried and tested PKing experience, I've learned a way to piss off Sherfags while PKing them during the situation when you move away from the legion to hunt someone down.
Sherfags tend to just get near you and hold down the "Ctrl" key to fight. Try during the mid-swing pressing the down arrow to get out of their range and quickly zip behind them and attack. They take a while to face you, in which during that time you zip behind them again and repeat.
This method has worked for me quite well when the legion isn't immediately there to fight with me.
AIDS: 4453
PostPosted: Sun Aug 26, 2007 7:43 pm    AIDS subject: Reply with quote
There are tons of fags that use that same technique, and it fails, because it takes them longer to go behind me and turn around to hit my back side, than it does for me to spin around and hit them a couple times before they turn around.
Funny thing is, many fags die due to it, not realizing all their doing is giving me chances to hit them, and the do it constantly and never figure it out.
PostPosted: Sun Aug 26, 2007 10:11 pm    AIDS subject: Reply with quote
True, but most of these 9 year olds can't figure that out and end up getting killed.
This forum is locked: you cannot make, reply to, or edit pools.   This pool is closed: you cannot edit AIDS or make replies.    Pool's Closed Forum Index -> Sherwood Dungeon Archive All times are GMT
