SHAVED BALLS
Goto page 1, 2  Next
Firingmehlazer
Nigra Lazer Squad
AIDS: 1230
Pools: 12
PostPosted: Thu Sep 06, 2007 8:34 pm    AIDS subject: SHAVED BALLS Reply with quote
I am experimenting with ball stretching a little. This leaves me fighting with the hair on my balls getting pulled and irritating the skin under my "o" ring I put around them. I have tried shaving them in the past, but it made them so damn itchy I was left embarrassing myself everywhere I went having to scratch them. So my question, for the guys here that shave is, how do you prevent the itching? Or is it just me?
Thanks
View nigra's profile Send private message Send e-mail AIM Address MSN Messenger
PostPosted: Thu Sep 06, 2007 9:30 pm    AIDS subject: Reply with quote
I personally have been shaving my balls for about the past 5 years.
And from my own experience, I have noticed that they tend to itch more when you get lazy on the shaving. Basically it's much like facial shaving. If you let it go, you get that 5 o clock shadow. wink.gif
So as long as you keep them like a baby, they shouldn't give you too much trouble.
Now if the itch is coming from razor burn or something of such. My suggestion would be to try a sensitive skin shave cream and make sure you use a brand new, and sharp razor.
But watch for cuts.
NOUSeaking
Warnings : 2
AIDS: 218
AIDS Rank: AfroMaster
Pools: 4
PostPosted: Thu Sep 06, 2007 9:44 pm    AIDS subject: Reply with quote
Stretching your balls huh.gif , OK enlighten me plaese I have never herd of this.
I shave em' but I go with a crew-cut laugh.gif , I tried the razor one time and will never do it again. but just keeping the hair short does not itch mine at all.
Have fun
PostPosted: Thu Sep 06, 2007 10:09 pm    AIDS subject: Reply with quote
http://www.poolsclosed.us/forum/viewtopic.php?t=6703
I shall now raep this entire thread for everyone failing to LURK THE FUCK MOAR
PostPosted: Thu Sep 06, 2007 10:32 pm    AIDS subject: Reply with quote
Have fun
Ball stretching is a process where you get your nuts to hang really low. Usually by means of tying something around them and leaving it there, not too tight, of course, then you would have no balls smile.gif. I am doing the method where I push one, then the other nut through a rubber "o" ring that is barely big enough for them to pass through. eventually I will add one more, then another, and so on. The goal is to stretch the skin of the scrotum and testicular cords slowly, so as not to cause damage. Kind of like foreskin restoration, which I am also doing. I want to be like a basset hound, with balls that almost touch the floor. Hey, I have heard of guys that can actually get their balls in their ass; that takes some real loose nuts.
Thanks, by the way, for the input on shaving. I guess I will have to make a choice, then. If I shave them, they will have to stay clean for the rest of my life, because I don't think I can go through a whole week of incredible itch like that again, unless I can stay home to deal with it for that long.
PostPosted: Thu Sep 06, 2007 10:37 pm    AIDS subject: Reply with quote
Rubber will always pull your hair. If you dont want to shave your balls, get yourself a ball stretching ring of steel. They have a smoots surface, and the hair wont be pulled. For your safety, get one that can be disassembled. They come in a version that cant be opened, where you put the balls trough one by one, but if something goes wrong, you cant get it off.
LSF
i hate people who have a different skin
AIDS: 1660
Pools: 169
PostPosted: Fri Sep 07, 2007 1:05 am    AIDS subject: Reply with quote
I was going to suggest trimming the hairs short but not shaven, but someone beat me to that!
To relieve itching, try Gold Bond powder. It contains menthol and is good at relieving itch.
I've used wide rubber bands and O rings as ZEBRA SALAD TOSSING toys - Fun, but they do tend to catch and pull on hairs! You might try leather cock / ball rings with snaps, available in a dazzling variety of styles at better cOoKiEs shops, but a bit expensive.
I once fashioned a ballring stretcher out of a piece of elastic waistband from an old pair of undershorts and some velcro - took a bit of sewing, but it worked. The velcro makes it adjustable and easily removable. Only problem was it was a bit too stretchy, my balls would sometimes slip back through.
Hmm, come to think of it, denim might be a better material to make a ball ring. With a little effort, some velcro and surplus denim (cutoffs of worn out jeans) you could make an entire set with different length "cuffs". It would sure look macho.
Just thought of another option - Try wrapping a small piece of cloth around your scrotum, then put the rubber O ring or rubber band over that to hold it in place. Protect those crotch hairs
PostPosted: Fri Sep 07, 2007 1:56 am    AIDS subject: Reply with quote
I just use a moisturizing shaving cream, works wonders.
Pink Ranger
AIDS: 433
AIDS Rank: WRYYYYYYYYYYYYYYYYYYYYYYYYY
Pools: 23
PostPosted: Fri Sep 07, 2007 2:50 am    AIDS subject: Reply with quote
I've found that placeing magnets in my rectum is quite pleasurable
PostPosted: Fri Sep 07, 2007 7:11 am    AIDS subject: Reply with quote
Zippo and can of lysol works wonders on bushy balls.
Firingmehlazer
Nigra Lazer Squad
AIDS: 1230
Pools: 12
PostPosted: Fri Sep 07, 2007 4:18 pm    AIDS subject: Reply with quote
Lol k sorry.
Raep away.
LSF
AIDS: 1660
Pools: 169
PostPosted: Fri Sep 07, 2007 5:55 pm    AIDS subject: Reply with quote
I've used wide rubber bands and O rings as ZEBRA SALAD TOSSING toys - Fun, but they do tend to catch and pull on hairs! You might try leather ಠ__ಠ / ball rings with snaps, available in a dazzling variety of styles at better cOoKiEs shops, but a bit expensive.
Fuck those other guys, trust me. I know how to stretch out my scrotum. Why do you think I can't have kids anymore because I keep tripping on my testes?
PostPosted: Fri Sep 07, 2007 7:12 pm    AIDS subject: Reply with quote
hey who the fuck
Did you leave PC on like Sodaz did?
PostPosted: Sat Sep 08, 2007 1:38 am    AIDS subject: Reply with quote
LSF
AIDS: 1660
Pools: 169
PostPosted: Sat Sep 08, 2007 2:05 am    AIDS subject: Reply with quote
My Birthday Wish is BUNNY PICTURES!!
As many cute bunny girls as possible, not furry ones just bunny girls or as I call them Usagi's.
ORGASMIC CROCODILE or Not I don't mind I'd like both ^.^ This would be the best birthday present anyone could give me cause I want my collection of bunny girls to grow. I'm always searching for new ones but their not as common as those kitty girls. So
Please please please please!! For the birthday girl ^.^
Thankyou Everone and Happy Holidays!!
LOVE YOU!!
~Bunny
Goto page 1, 2  Next
Page 1 of 2
