This banner was made by OBEY! Jesus.
halp
Guy Fawkes
AIDS: 69
AIDS Rank: DESU
Pools: 5
PostPosted: Fri Sep 07, 2007 2:07 am    AIDS subject: halp Reply with quote
Is the Vista "Genuine Advantage" shit really all that effective in removing my ability to wear an eye patch and own a peg leg?
Is there some way to remove or subvert it? I like being a pirate... pirate
AIDS: 3637
Pools: 357
PostPosted: Fri Sep 07, 2007 2:10 am    AIDS subject: Reply with quote
http://keznews.com/2450_Paradox_Vista_activator___WGA_crack
You can thank me later.
itt i whore out my profile
CLICK EIRI YUKI TO ENHANCE THE GREAT CITYSTATE OF PEN0SLAND
http://pen0sland.myminicity.com/ind
ALSO, INDUSTRY.
http://pen0sland.myminicity.com/tra
AND TRANSPORTATION
http://pen0sland.myminicity.com/sec
AND SECURITY
ADMIN WARFARE 101
Tom Anderson
Myspace.com
AIDS: 354
YOU BET YOUR SWEET ASS
Nigga Bah Nigga Mah Nigga, NIGGA!
Guy Fawkes
AIDS: 69
AIDS Rank: DESU
Pools: 5
PostPosted: Fri Sep 07, 2007 2:15 am    AIDS subject: Reply with quote
Holy shit thanks!
red shoe paul
Dome Rocker
AIDS: 784
Pools: 66
PostPosted: Fri Sep 07, 2007 1:40 pm    AIDS subject: Reply with quote
This is MAH CREW! PARADOX.
Will this work on Vista Ultimate? :D
I'll need it for the future.
nothing0011
OSU!
AIDS: 846
Pools: 41
PostPosted: Fri Sep 07, 2007 2:47 pm    AIDS subject: Reply with quote
I got a pre cracked copy if you want it.
AIDS: 3637
Pools: 357
PostPosted: Sun Sep 09, 2007 2:19 am    AIDS subject: Reply with quote
Yes. 32 bit only.
ALSO, INDUSTRY.
AND TRANSPORTATION
AND SECURITY
ADMIN WARFARE 101
Guy Fawkes
AIDS: 69
AIDS Rank: DESU
Pools: 5
PostPosted: Thu Sep 13, 2007 12:43 am    AIDS subject: Reply with quote
Anyone know how to optimize my CPU/RAM usage? Vista eats a lot of it and I intend to download games.
My specs are:
AMD Athlon(tm) 64 X2 Dual Core Processor 5000+ 2.6 Ghz
3 GB of RAM
Nvidia Geforce 7900 GS graphics
EpicFailGuy
I'm about to Ruin this thread
AIDS: 269
Pools: 7
PostPosted: Thu Sep 13, 2007 1:14 am    AIDS subject: Reply with quote
My specs are:
3 GB of RAM
Do a clean install via formating with the Vista disk that came with your comp, then after it's done, go in and disable anything you aren't going to be using (Windows Defender and Firewall must be raep'd. Period.)
Afterward, check your running processes. If it's running and you don't know what it is, find out or stop it. Rinse repeat until RAM is maximized.
Then launch game. Play until content.
TL;DR
1> Format, clean install
2> Disable lame Windows Firewall and Defender
3> Close all processes you aren't using
4>Launch game
5> ???
6> Profit!
TehSmurphs
AIDS: 101
AIDS Rank: OMGWTFBBQ!?!1!!?1!!
PostPosted: Tue Sep 18, 2007 3:52 am    AIDS subject: Reply with quote
Do want. I'll run it in VMWare, because I refuse to taint my hard disk with an actual install of Vista.
