This banner was made by Afroduck.
Dummy accounts
This forum is locked: you cannot make, reply to, or edit pools.   This pool is closed: you cannot edit AIDS or make replies.    Pool's Closed Forum Index -> Habbo English
robtard94
AIDS: 5
PostPosted: Thu Nov 15, 2007 4:26 am    AIDS subject: Dummy accounts Reply with quote
New to the site and raiding, not to /b/ so hi :D
ok here are some UK Habbo accounts that I've created.  Use them wisely ;)
Note: The names suck because I didn't want admins to be able to go through profile lists and have an easy time figuring out whose a raider and whose a 12 year old girl.  All profiles are nigra'd out already so no setup time is needed.  If you need to use the email for anything, just make the account [which takes like...2 minutes]
password: chikkihawt1
email: hawtchikki1@gmail.com
password: desuluvsme1
email:  desudesu999@gmail.com
password: powaemo999
email:  emoemoemo999@gmail.com
password: bawww999
email: bawww999@gmail.com
password: ofebaumsworld1
email: andonlyericbauman9@gmail.com
password: lawdylawdy999
email: nigchig1992@gmail.com
More to come, but I'm going to play call of duty 4 so cheers
Goatse
View nigra's profile Send private message MSN Messenger
AIDS: 4453
PostPosted: Thu Nov 15, 2007 4:35 am    AIDS subject: Reply with quote
Just a few things
1- No need for the fag names. Admins/mods don't go through the lists, solely because its millions of names, that and they're to lazy, as long as it isn't overly offensive.
2- No need to give out names/passes unless you just came up with a script of some sort to make nigras for you. We had it in the past, but haven't needed it nor does it work anymore either.
3-You don't even need an email. I put advertising@ebaumsworld.com as mine, just so all the junk mail gets sent to them. The most they could do with it is hijack the nigra account, which will probably be banned soon afterwards anyway.
4-Its on the US server
5- LURK MOAR
Tom Anderson
Myspace.com
AIDS: 354
PostPosted: Thu Nov 15, 2007 5:34 am    AIDS subject: Reply with quote
94?
We got sum srs underage-eurofag-b& here
Nigga Bah Nigga Mah Nigga, NIGGA!
robtard94
AIDS: 5
PostPosted: Thu Nov 15, 2007 6:24 am    AIDS subject: Reply with quote
Tom Anderson wrote:
94?
1.  I'm 16, underage by some standards but whatever.  Age doesn't define maturity ;)
2.  Shit, didn't see that it was on US servers.  My bad.
3.  Any specific place you recommend lurking?
lulzDUCKROLLlulz
AIDS: 59
AIDS Rank: FGSFDS
PostPosted: Thu Nov 15, 2007 6:32 am    AIDS subject: Reply with quote
robtard94 wrote:
Tom Anderson wrote:
94?
3. ?Any specific place you recommend lurking?
http://www.habbolol.dr.ag - habbochan
robtard94
AIDS: 5
PostPosted: Thu Nov 15, 2007 6:42 am    AIDS subject: Reply with quote
that was certainly pleasant...now without any bugs in eyes/genitals/other orifices, is there any particular place where I can go to get the full facts on this so I don't make a further arse of myself?
PostPosted: Thu Nov 15, 2007 11:44 am    AIDS subject: Reply with quote
Why are you making all these faggoty smileyfaces? Also why aren't you blocking the pool?
And you can try lurking onwww.coolsplosed.com.
PostPosted: Fri Nov 16, 2007 8:01 am    AIDS subject: Reply with quote
Yes, rope. Hang on on the roof, make a noose then put your neck on it then jump off from a stool.
This forum is locked: you cannot make, reply to, or edit pools.   This pool is closed: you cannot edit AIDS or make replies.    Pool's Closed Forum Index -> Habbo English All times are GMT
