Tools and Shit
This forum is locked: you cannot make, reply to, or edit pools.   This pool is closed: you cannot edit AIDS or make replies.    Pool's Closed Forum Index -> Sherwood Dungeon Archive
Sodaz
F-O-E
AIDS: 2110
Pools: 163
PostPosted: Thu Aug 09, 2007 5:17 pm    AIDS subject: Tools and Shit Reply with quote
LOLTOAST's cheating method-
LOLTOAST wrote:
Okay, I figured out a way to cheat.
Download:
http://www.cheatengine.org/CheatEngine53.exe
Select either firefox.exe or iexplore.exe depending on your browser.
Nigra Run and Attack Steriods:
Then check the 'Enable Speedhack'. Set the speed to 1.5, and click set speed. More then 1.5 will log you out.
Potion Hax:
For potions you have to type /level 4 first
Type in the amount of your potions into the value spot. Press enter.
Then drink a potion and search the new amount of potions.
Double click the right value, then double click the value at the bottom, change to what you want.
Then drink a potion.
Money Hax:
test22 wrote:
Money explained
2.Connect to the game
3.Go to the Merchant
4.Search for your amount of Gold
ex. if you have 100 coins then search 100
5.You will get alot of addresses.
6.Then buy an item then your money will deduct. You will have ex. 50 Coins Left. search 50
7.1,2 or 3 Addresses will show up edit all their values to the amount of Money you like!
8.Use a potion
One Hit Kills-
1. Get two nigras.
2. Get the other nigra to attack you while you are blocked.
3. Use cheat engine, search for 1.
4. Ge tthe other nigra to attack you while you are blocked again.
5. Search for 2.
6. If there is more than 1 value, keep doing it.
7. When you get one value set the value to 99999 and freeze it.
8. ?????
9. One hit kills & profit.
LOLTOAST's raid tool
1)First download this(Only works on Windows)
http://files.filefront.com/Sherwood+Raid+Tool+3zip/;8264040;;/fileinfo.html
2)Unrar the file and run the program.
3)Select the driver your using and your Windows account name.
4)Save your current data to slot 1(Sherwood cannot be running when you do this)
5)Load the nigra save for LOLTOASTs level 18 nigra
6)Next time your in the game change to a normal spartan. Currently LOLTOASTS special color does not work
Enchantment of speed cheat
LOLTOAST wrote:
Use cheat engine.
1. Use the Enchantment of Speed (TAB button)
2. Search for 1 in Cheat Engine
3. Press attack button (CTRL button)
4. Search for 2 while the yellow is going down.
5. Search for 3 while the blue is refilling.
6. You should select the value you got, change it to 1 and freeze it there.
7. ?????
8. Exploding Vans.
Tested this with speed hack at 1.5 its fucking awesome.
Thats all for now. AWSOME!
http://pools.myminicity.com/
Go there and help the glorious republic of pools closed grow.
Current Population-50
Current monies-7500
We have a small community in the center and some farms. Also we're doing better then pen0sland.
lulzDUCKROLLlulz
AIDS: 59
AIDS Rank: FGSFDS
PostPosted: Sat Aug 11, 2007 10:30 am    AIDS subject: Re: Tools and Shit Reply with quote
b]LOLTOAST's raid tool[/b]
and after that:
why it fail?
edit:
i found out why it doesn't work.
BixNoodles
AIDS: 4
PostPosted: Mon Aug 20, 2007 10:52 pm    AIDS subject: Reply with quote
do these cheats work forever or are they temporary?
Sodaz
F-O-E
AIDS: 2110
Pools: 163
PostPosted: Mon Aug 20, 2007 11:01 pm    AIDS subject: Reply with quote
One hit kills and enchantment of speed hack are temporary.
Current monies-7500
B&_and_V&
AIDS: 2
AIDS Rank: joecoolstar
PostPosted: Mon Aug 20, 2007 11:32 pm    AIDS subject: Reply with quote
Word, now I'm prepared.
Longcatislooooo
AIDS: 1
PostPosted: Tue Aug 21, 2007 8:13 pm    AIDS subject: Reply with quote
Ahh nevermind, figured it all out by myself.
JeDrEk:D
AIDS: 1
PostPosted: Wed Aug 29, 2007 8:15 am    AIDS subject: Re: Tools and Shit Reply with quote
and after that:
why it fail?
edit:
I have this problem :[ Help me!!plz
This forum is locked: you cannot make, reply to, or edit pools.   This pool is closed: you cannot edit AIDS or make replies.    Pool's Closed Forum Index -> Sherwood Dungeon Archive All times are GMT
